Mis peaks siis esimesena ära vahetama, tahaks kiirendust juurde veits, aga et eriti kütusekulu ei mõjutaks. Rolleriks on Jonway31 2 taktiline.
Jama jutt! Engine size: 49.5CC Approvals: EEC, DOT, EPA Dry weight: 120kg Wheel base: 1,350mm Exterior size: 1,980 x 680 x 1,120mm Maximum speed: 50kph Maximum payload mass: 165kg Fuel capacity: 6L Brake type: (F) drum, (R) disk Engine type: two-stroke, single cylinder, forced, air-cooled Maximum power: 5.8kW, 7,500rpm Starting system: electric and kick start Tire size: 130/60-13PR, 130/60-13PR Battery size: 12V, 7Ah
