M: Stage 6 EGT näidik
Discussion in 'Müük' started by Kossur, Mai 21, 2016.
  1. Kossur
    Kossur Member
    349
    Tere
    Müüa tutikas Stage 6 EGT näidik. Ehk aitab mõnel tuunijal enda masin paremini timmi ajada või niisama lisa vidin külge panna. Endal ei olnud seda vaja.
    Hinda küsiks selle kasutamata asja eest 75 eurot.
    Väike lisainfo: This exhaust gas temperature gauge is a neat instrument for setting up your engine and carb – and it’s available at a bargain price. The temperature will be measured and displayed in real-time, allowing for easy carb adjustment. As you probably know, a too-lean mixture burns at a very hot temperature, while the exhaust gases of a too-rich mixture don’t reach a certain temperature. No welding necessary! In order to achieve optimal engine performance, the spark plug should be brown. Using smaller jets increases performance further but also leads to a white sparkplug and eventually to engine seizure. You have to use a jet which results in a mixture so lean that you get an exhaust gas temperature of 650° on a straight with full throttle. Depending on the material, hotter temperatures are also ok, but you will have to be careful, since overheating can lead to a piston seizure; an integrated warning function can be used. Display readings are between 0 and 1200° C.
    Asub Tallinnas Nõmmel.
    Kirjutage postkasti.
  2. Kossur
    Kossur Member
    349
    Müüdud!
