Nii, oleks siis vaja teie soovitusi. Missugune tuuning siduritrummel on parima hinna/kvaliteedi jms. suhtega ? Ise ei osanud eriti otsida. Paluks täpseid linke jms. Siduritrummlit on vaja Minarelli Horisontaalile, sidur on 107mm.
Endale tellin Stage6 oma , pidavat täitsa hea olema. Mingi 35 eur umbes. :wink: Lingi saad ise ka otsida scooter-attackist näiteks. :wink:
Tuleb nii välja Clutch bell Stage6 Strengthened clutch bell with patented cooling concept. The air flows through the side fins and the enlarged drills to the clutch facings. This results in longer life for the clutch and reduced clutch slip when the engine is warm. The bell's temperature will be considerably lower which leads to less waste energy and higher performance at the rear wheel. Better acceleration also with warm engine. The bell interior was sand streamed to increase the linings' grip. The lower mass of only 395g (compared with Malossi Wingbell 575g, Polini Evolution 485g) has positive effects on the engine's acceleration.
