Stage6 sportsummuti
Discussion in 'Soovitused' started by aeroximees, Apr 12, 2008.
  1. aeroximees
    aeroximees New Member
    348
    Et mis te Stage6 PRO Replica CE Exhaust Chrome arvate ,et kas see sumps on hea?http://www.scooter-attack.com/index2.php?lang=e
    Kuidas on ta võrreldes nt. Yasuni - R'ga?
  2. v-501
    v-501 New Member
    750
    r- on veits kõvem, aga välimus on stage 6el parem
  3. aeroximees
    348
    Hinna vahe on ka mingi 20 euri või rohkemgi
  4. oliver53
    oliver53 New Member
    57
    yasuni R on perf. poolest kindlalt parem kui see stage 6 :wink:
  5. aeroximees
    348
    Ma kaldun arvamusele et mulle meeldib stage6 kuna ta välimuselt lahedam ja odavam ka mingi 20 euri
  6. K-1
    K-1 Member
    291
    Ok, it has the magical three letters MHR in its name, but will it live up to the expectations? We tested it on a Minarelli engine with a Trophy, a Stage6 Pro and a Stage6 Racing kit, carburettor was 17.5mm.
    Vario was blocked to see exactly at what Rpm the pipe makes best power, and also to check what torque it makes.
    All dyno runs were done with an aircooled Minarelli engine with standard 12mm carb (!) and standard airfilter. Best jet size was between 85 and 93, depending in which exhaust was used. Variator was a polini 2003. The blue curve is from a Polini 70cc Sport, red graph is from a Stage6 Sport PRO. Both cylinders used the Yasuni R as an exhaust.
  7. vol-com
    vol-com New Member
    231
    Ehk, et selle põhjal peaks stage 6 parem olema kõrgematel pööretel ? :roll: :D
  8. tgb303r
    tgb303r New Member
    jumalast pohhui milline ta välja n2eb peaasi et ta midagi sulle juurde annab:D
  9. raitonrait
    raitonrait New Member
    808
    kui see sinuarust veel lahja on sebi r1200 voi r1400 omab enamus asjad 2ra,
    mul oli võimalus võrrelda yasuni r ja r1200 (athena racing) summutit, yasuni r oli t2is saast
  10. -Aprilia-
    -Aprilia- New Member
    194
    yasuni r on 70cc -tele ja stage6 50cc- tele juu.... :?
  11. awerx
    awerx Member
    188
    ma ei tea mul olid yasuni-r ja see stage6 lükkasin selle stage6 alla mõtlesin et liigub normaalselt:D aga kui lükkasin yasuni-r alla siis oiplää kus tuli juurde :) ja noh mootoris oli ka 50sport. ja mulle see stage6 meeldib välimuselt muidu aga häälon ka minu arust vastik yasuni-riga võrreldes selline pleki hääl.
