parim mid-race silinder.
Discussion in 'Soovitused' started by Italkit, Sept 28, 2011.
  1. Z0ne
    Racingust peaks saama veidi rohkem hobujõude pigistama, aga võib ka mitte.
    Keegi üldse teab mis piirist algab ning lõppeb mid-race?
  2. try all
    try all New Member
    821
    racingust saab rohkem küll välja pigistada , aga see on nii vähe, ja replica peab sitaks paremini vastu , ikka vägapalju paremini.
  3. StreetBuzz
    Ja millest sa seda järeldad ? :lol: Asjatundjad koos (Y) 8)
  4. Possible
    Possible Active Member
    1,411
    natuke netis ringi kolades leiab sellised tekstid nende silkude kohta::
    Stage 6 racing:
    The Stage6 RACING cylinder is an aluminium cylinder with extreme potential high up
    into the HighEnd range. Different from the Sport PRO, the RACING has a big bridged
    exhaust port, longer port durations and considerably higher compression. Depending
    on the components used, 14 to 21 hp can be expected!
    Malossi MHR replica:
    The MHR Replica is a 70cc aluminium racing cylinder comparable in performance to Polini Corsa. As the MHR Replica is made of aluminium, which dissipates heat better than cast-iron, it has much better thermal properties than the Corsa though. In order to ensure sufficient inner cooling and to achieve good performance, we recommend at least a 17.5mm carb. We also suggest using a Stage6 Pro exhaust or the Nardo from Top Performances. Yasuni C16 offers high revs, but top performance isn’t that good.
    Performance 9.5 - 12.5 hp
    kui nii võtta ja neid andmeid uskuda, siis üle 5hp vahe on ikka päris märgatav...
    need andmed on pärit:
    stage6-racing.com ja scooter-attack.com
    8)
  5. peremees
    ei olene vanusest,koguaeg kahte varianti müüdud.
