UUS TUUNINGUTURUL!
Discussion in 'Tuuning' started by K-1, Nov 8, 2007.
  1. pekk
    pekk Active Member
    1,031
    Re: UUS TUUNIGUTURUL!
    easyparts
  2. KuKiMuKi
    KuKiMuKi New Member
    1,066
  3. tegija99
    tegija99 New Member
    144
  4. Põrguvärk
    1,683
    Polini on teinud Piaggio mootorile uue silindri mille kolvi läbimõõt on 52,0mm.
    Ja mitte ainult silindri,vaid ka väntvõlli mille käik on 44mm.
  5. speed fighter
    speed fighter New Member
    905
    aga airsalil on nüüd bigbore silku!
  6. builder3
    builder3 New Member
    229
    attackis nüüd uued S6 R/T 70ccm silindrid müügil ja ei olegi nii kirves nagu ennustada võis.
    päris mõnusat võimsust pidi ka suutma arendada 70se kohta ;)
  7. KuKiMuKi
    KuKiMuKi New Member
    1,066
    Kus sa seda nägid???
    Ja mis masinale need on, ma neid aeroxite alt ei leidnud igatahes.
  8. JussPB
    JussPB Active Member
    1,384
    19
    Piaggiodele oli minuarust, minarellidele ei tea kas on juba väljas vms..
  9. Brabus
    vaatan ka ,et v2ljas , hind 330 euri , aga mingit muud infi kyll pole
    EDIT: jap , päris karm silku
    The cylinder that has been breaking records! It set new best times in the Italian Open Cup and also broke the magical 6-second barrier in scooter dragracing.
    Regarding transfer port layout, Stage6 has maintained GP standards, refraining from cross-section reducing 7- or 8-port designs. After all, “more” isn’t necessarily “better”.
    The 47.6 mm bore conforms to the rules of most 70 cc racing classes. The patented modular construction allows for very quick mounting of the cylinder to different engines via adaptors. Sealing between adaptor plate and cylinder is realized via a Viton® O-ring; this makes the tedious cleaning of sealing surfaces and replacing of gaskets unnecessary. Once the adaptor plate has been mounted and adapted via base seals, it won’t have to be readjusted.
    The CNC-milled adaptor plate bolts to the engine case and accepts the cylinder via the external studs. The construction of the R/T 70cc cylinder goes without continuous studs, so the design of exhaust and transfer ports isn’t subject to the restrictions of conventional racing cylinders and further tuning and porting reserves are available.
    Particular attention has been paid to the cylinder’s thermal properties. The CNC-milled inner cylinder head is bolted at five points, each of them thermally stabilized by its own cooling pocket. Thus the critical areas at the studs that tend to lead to piston seizures have been eliminated.
    The flange firmly connects the cylinder to the exhaust via three bolts, minimizing the leakage of fuel residues. Fitting flanges are available for all common racing exhausts and do-it-yourself kits are also available. The kit includes a fitting exhaust flange for the Stage6 R/T exhaust and installation instructions.
  10. Brabus
    Samuti on väljas 2 uut sumbutit stage6 poolt.
    üks siis Stock sumbuti välimusega , mis on tegelt mõeldud madalama klassi 70ste jaoks
    ja siis veel Stage6 R/T sumbuti , mis tuli koos R/T Silindriga välja , peaks siis R/T silkule parim olema , ja üldse highend sumpa , hinnaks 310 euri
  11. Põrguvärk
    1,683
    Tecnigas on turule toonud uued tooted:
    Tecnigas Trek on 50cc mootoritele mõeldud summuti mis peaks olema oluliselt jõulisem ja parem kui Next-R
    Tecnigas RS-2 On mõeldud kasutamiseks nii 50cc kui ka 70cc sport silindritega
    Tecnigas uus racing tootesari kannab nime Reverse. Kuna pilte ei õnnestunud copida, siis panen lingi .
    http://www.reverseexhausts.com/
  12. approx-
    approx- New Member
    816
  13. KuKiMuKi
    KuKiMuKi New Member
    1,066
  14. Raghza
    Raghza Active Member
    1,189
    Tundub küll üsna samasugune nagu TP DuePlus, lihtsalt see vahva roosakaspunane värvikiht on pealt kadunud. Pordid ka üsna samasugused.
  15. JussPB
    1,384
    19
  16. Brabus
  17. TUUR
    1,137
  18. Raghza
    1,189
    Ülimalt kena sumpa :)
  19. Simon
    Simon Active Member
    1,535
    +1.Siga kena sumpa
  20. speed fighter
    905
    kuju järgi on se nagu reverse. aga silenceri otsa on mingi julla topitud.
